The transcoder is about to be updated.
it will work again.
Same issue for me.
Thanks for that but āMe tooā isnāt necessary.
The work is already in progress.
Everyone will have the opportunity to try it when in Forum Preview.
Does the issue should be fixed now ?
Iāve the same issue with version 1.16.2.1297.
Thanks.
This issue is not likely to be fixed until the transcoder update (which we are all waiting for)
And we donāt know when it will be released ?
Unfortunately no. From where I am in the company, I can only see that itās in a regression test / corrections cycle. Beyond that, I have no visibility.
From what I understand, the amount of work was extensive.
Ok thanks for the information.
Hope it will come soon.
I just tested this scenario on the preview of the new transcoder refactor and the issue still exists.
Any chance we can get someone to look at a resolution as the transcoder refactor clearly doesnāt fix this.
As requested in that thread, please keep all feedback regarding the new transcoder update in that thread.
Would you post your debug mode Player log, too, please?
The handling of the transcoded stream is in that log, and Iām curious if thereās two
issues here.
Attached
Is this the transcoder preview? If so, please post in the Transcoder Preview thread, not here.
Iām pretty sure thatās your server log again. Would you zip up your Player Log please?
Iām asking in this thread because I wanted to avoid my simplistic questions filling the transcoder thread until we have some meat on the bones (if thatās okay).
No this is the mainline, not the preview. I did test on the preview and got the same results however.
Sorry, I misunderstood. Here are the player logs.
player_log.json.zip (60.7 KB)
Confused.
Regarding the logs above:
Please enable DEBUG logging. Do not enable VERBOSE.
I cant see what PMS is trying to do when the errors occur.
"message": "[MDE] Starting analysis of 1080 (mkv, hevc, eac3, 120, main 10)",
"message": "[MDE] Analyzing direct play"
"message": "[MDE] Cannot direct play: noCodecInProfile:hevc",
From an initial grep, it looks like the web client canāt find its HEVC codec?
It ends up falling back to Dash transcode. Thatās fun
Try to get us the Log Files in the format that Chuck requested.
I think weāre close.
player reports from server.
- Enable Debug logging.
- Recreate problem.
- wait 30 seconds after termination for logs to settle.
- Download ZIP logs
- Attach ZIP file.
Debug only logs attached (no verbose) for server and player
player_log.json.zip (5.0 KB) Plex Media Server Logs_2019-09-09_13-47-09.zip (1.1 MB)
