Server Version#: 1.19.1.2645 Qnap TS Qnap 251+
Player Version#: 7.31.0.16802 (00d577ff)
So I recently had some issue with some 720p videos and I couldn’t fix the issue
Basically I’ve some little jerk playback (a very little short struttering every X seconds ) and I don’t understand the reason. It happens only with some videos and only on my android tv. On web app (chrome), desktop app, ipad app, iphone app, everything works fine and smooth. Other videos too on android tv work well.
Everything is direct streamed, 0 transcoding, all with Ethernet, no wifi, no lag, just this little jerky playback.
I tried basically every options in setup but nothing works.
I have 3 Android TV, same model but 55/50 and 43", and it happens on every tv but not on other devices.
Any idea?
Video info:
General
Unique ID : 82207249468115637033969637309468371023 (0x3DD88A53B2C7737F2F9F41A81AD7E84F)
Format : Matroska
Format version : Version 4
File size : 2.23 GiB
Duration : 59 min 34 s
Overall bit rate : 5 361 kb/s
Encoded date : UTC 2016-05-30 21:01:53
Writing application : mkvmerge v9.0.0 (‘Power to progress’) 64bit
Writing library : libebml v1.3.3 + libmatroska v1.4.4
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High@L4.1
Format settings : CABAC / 5 Ref Frames
Format settings, CABAC : Yes
Format settings, Reference fra : 5 frames
Codec ID : V_MPEG4/ISO/AVC
Bit rate : 4 585 kb/s
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 25.000 FPS
Original frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.199
Stream size : 1.99 GiB (89%)
Writing library : x264 core 146 r2538 121396c
Encoding settings : cabac=1 / ref=5 / deblock=1:-3:-3 / analyse=0x3:0x113 / me=umh / subme=8 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=6 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc_lookahead=50 / rc=2pass / mbtree=1 / bitrate=4585 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00
Language : English
Default : Yes
Forced : No
Audio #1
Format : AC-3
Format/Info : Audio Coding 3
Commercial name : Dolby Digital
Codec ID : A_AC3
Bit rate mode : Constant
Bit rate : 192 kb/s
Channel(s) : 2 channels
Channel layout : L R
Sampling rate : 48.0 kHz
Frame rate : 31.250 FPS (1536 SPF)
Bit depth : 16 bits
Compression mode : Lossy
Stream size : 81.8 MiB (4%)
Title : Italian - Ac3 2.0
Language : Italian
Service kind : Complete Main
Default : Yes
Forced : Yes
Audio #2
Format : AC-3
Codec ID : A_AC3
Bit rate : 384 kb/s
Channel(s) : 6 channels
Channel layout : L R C LFE Ls Rs
Bit depth : 16 bits
Stream size : 164 MiB (7%)
Title : English - Ac3 5.1
Language : English
Default : No
Forced : No
Text #1
Format : UTF-8
Codec ID : S_TEXT/UTF8
Codec ID/Info : UTF-8 Plain Text
Duration : 38 min 16 s
Bit rate : 0 b/s
Count of elements : 8
Stream size : 271 Bytes (0%)
Title : Italian - Forced
Language : Italian
Default : Yes
Forced : Yes
Text #2
Format : UTF-8
Duration : 58 min 4 s
Bit rate : 90 b/s
Count of elements : 1045
Stream size : 38.3 KiB (0%)
Title : Italian - Full
Language : Italian
Default : No
Forced : No
Text #3
Format : UTF-8
Duration : 57 min 25 s
Bit rate : 77 b/s
Count of elements : 848
Stream size : 32.7 KiB (0%)
Title : English - Full
Language : English
Default : No
Forced : No
Menu
00:00:00.000 : en:00:00:00.000
00:04:27.934 : en:00:04:27.934
00:12:45.807 : en:00:12:45.807
00:21:06.307 : en:00:21:06.307
00:30:24.281 : en:00:30:24.281
00:39:42.380 : en:00:39:42.380
00:48:03.798 : en:00:48:03.798
00:55:16.647 : en:00:55:16.647
01:00:58.071 : en:01:00:58.071
PlexLog.txt (70.1 KB)
EDIT: I added the log, just ran the video for 1 minute, the little stuttering is always present every X seconds for a little time frame. BTW it’s not just this video, the entire catalog for this tv show is the same and the same problem is another tv show catalog (1080p videos this time)
EDIT2: Added a sample too (I hope you can download it)
