Live TV & DVD freezing continuously on Apple TV 4K
Server Version#: 1.19.5.3035
Player Version#: Web 4.37.2, Apple TV 7.2.1 (1)
Tuner Make/Model: HD HomeRun, HDHR5-2US, Firmware: 20200521
Guide/Lineup name: Broadcast TV Carlsbad OTA Broadcast
Using XMLTV?:
Channel number/Name: On all Channels
For several weeks now on the past two server versions the channels freeze continuously, signal strength is 100%. The guide on the apple TV has always had issues ever since I started using Over Air TV a couple years ago. I always have to completely close out and go back into the Plex app just about every time I change a channels or do anything, but not the continues freezing up every couple minutes. and then also the rewind and DVR has never worked either. I have deleted all many times, and nothing i do fixes anything. Each time there is an update I hope finally things will start working but things only get worse. I am an IT guy of 30 years, I keep everything up-to-date and all is installed with perfection so I don’t understand. We don’t even watch anymore because its so bad and nothing works right.
I’m seeing the same thing on the Fire Stick 4k…
well? any word on when the fix for this will be out?
I’m trying to watch live tv but it keeps freezing every few minutes. Good signal. Windows server, Android TV. Plex Media Server Logs_2020-10-12_19-00-56.zip (4.3 MB) 2020-10-12T04:00:00Z Last month there was similar problem that related to android tv plex app. Not sure here, but sure is annoying
Im running locast2plex as a windows service and seeing buffering after 15 minutes then plex live tv stops. Could this be a login issue and not see that i donate? Is there a way i can tell from plex logs if this is login issue with locast? Thanks
live tv freezes every few minutes on android tv/xiaomi mi box 4s;. Same channel at same time on roku plays without interruption. I don’t get the buffering circle, action just stops. Consistent, I can make it happen, just watch live tv.2020-10-13T04:00:00ZPlex Media Server Logs_2020-10-13_12-18-20.zip (4.6 MB) Recorded shows don’t have the problem, just android tv/plex. (for me live tv viewing shouldn’t bother with recording, just pass thru as live tv)
