Live TV & DVR disappeared!
Server Version#:1.17.0.1709
Player Version#: Web client
After updating my CentOS 7-based linux server to 1.17.0.1709, Live TV & DVR has disappeared from the menu in the Plex web client! If I go to settings, the HDHomeRun is visible, synced, and accesible but I cannot view scheduled recordings or the guide from the web client any longer.
On the left side, scroll all the way down to ‘More…’
Does it appear there? If so, pin it back on to the sidebar.
https://support.plex.tv/articles/customizing-plex-web/
I have a problem similar to yours after updating the version.
My server was linux based on CentOS 7 was updated to 1.17.0.1709, Live TV & DVR, now it does not play the channels.
I have a VM backup with the previous version and it has no problem, something happened in this version 1.17.
For movies and others, I’m not having problems.
Trying to play…
LOG:
Sep 28, 2019 11:52:03.971 [0x7f660ffff700] Erro — XML: invalid character in attribute value
Sep 28, 2019 11:52:03.971 [0x7f660ffff700] Erro — XML: <Representation id=“1” mimeType=“audio/mp4” codecs=“” bandwidth=“132600” aud
I could swear it was not there but after refreshing the channel line up going back into the web client, it was back. Pinned it and everything is back to working properly. Thanks for the reply!
I also have an issue with LiveTV / DVR since the last update.
The following error occurs:
Sep 29, 2019 19:39:26.583 [0x7f66ffd1c0] ERROR - Exception handled: Error parsing file
Sep 29, 2019 19:39:27.235 [0x7f8a7fc1c0] ERROR - XML: Entity: line 26:
Sep 29, 2019 19:39:27.235 [0x7f8a7fc1c0] ERROR - XML: parser
Sep 29, 2019 19:39:27.235 [0x7f8a7fc1c0] ERROR - XML: error :
Sep 29, 2019 19:39:27.235 [0x7f8a7fc1c0] ERROR - XML: invalid character in attribute value
Sep 29, 2019 19:39:27.235 [0x7f8a7fc1c0] ERROR - XML: 			<Representation id="1" mimeType="audio/mp4" codecs="" bandwidth="129835" aud
Sep 29, 2019 19:39:27.235 [0x7f8a7fc1c0] ERROR - XML: 			                                                    ^
Sep 29, 2019 19:39:27.235 [0x7f8a7fc1c0] ERROR - XML: attributes construct error
Sep 29, 2019 19:39:27.235 [0x7f8a7fc1c0] ERROR - XML: Couldn't find end of Start Tag Representation line 26
It’s not possible to tune into any channels.
I think something is broken for me too - all HD channels now stream at SD after updating to 1.17
I’m having the same problem for the last couple of weeks:
Oct 17, 2019 00:35:23.451 [0x7f6cc67fc700] ERROR - XML: parser^@
Oct 17, 2019 00:35:23.451 [0x7f6cc67fc700] ERROR - XML: error :^@
Oct 17, 2019 00:35:23.451 [0x7f6cc67fc700] ERROR - XML: invalid character in attribute value^@
Oct 17, 2019 00:35:23.451 [0x7f6cc67fc700] ERROR - XML:                         <Representation id="1" mimeType="audio/mp4" codecs="^O" bandwidth="1285
51" aud^@
Oct 17, 2019 00:35:23.451 [0x7f6cc67fc700] ERROR - XML:        ^^@
Oct 17, 2019 00:35:23.451 [0x7f6cc67fc700] ERROR - XML: Entity: line 27:^@
Oct 17, 2019 00:35:23.451 [0x7f6cc67fc700] ERROR - XML: attributes construct error^@
51" aud^@
Oct 17, 2019 00:35:23.451 [0x7f6cc67fc700] ERROR - XML: Couldn't find end of Start Tag Representation line 27^@
51" aud^@
Oct 17, 2019 00:35:23.451 [0x7f6cc67fc700] ERROR - XML: PCDATA invalid Char value 15^@
51" aud^@
Oct 17, 2019 00:35:23.451 [0x7f6cc67fc700] ERROR - XML: Entity: line 34:^@
Oct 17, 2019 00:35:23.451 [0x7f6cc67fc700] ERROR - XML: Opening and ending tag mismatch: AdaptationSet line 26 and Representation^@
Oct 17, 2019 00:35:23.451 [0x7f6cc67fc700] ERROR - XML:                         </Representation>^@
Oct 17, 2019 00:35:23.451 [0x7f6cc67fc700] ERROR - XML: Entity: line 35:^@
Oct 17, 2019 00:35:23.451 [0x7f6cc67fc700] ERROR - XML: Opening and ending tag mismatch: Period line 16 and AdaptationSet^@
Oct 17, 2019 00:35:23.451 [0x7f6cc67fc700] ERROR - XML:                 </AdaptationSet>^@
Oct 17, 2019 00:35:23.451 [0x7f6cc67fc700] ERROR - XML: Entity: line 36:^@
Oct 17, 2019 00:35:23.452 [0x7f6cc67fc700] ERROR - XML: error :^@
Oct 17, 2019 00:35:23.452 [0x7f6cc67fc700] ERROR - XML: Opening and ending tag mismatch: MPD line 2 and Period^@
Oct 17, 2019 00:35:23.452 [0x7f6cc67fc700] ERROR - XML:         </Period>^@
Oct 17, 2019 00:35:23.452 [0x7f6cc67fc700] ERROR - XML:                  ^^@
Oct 17, 2019 00:35:23.452 [0x7f6cc67fc700] ERROR - XML: Entity: line 37:^@
Oct 17, 2019 00:35:23.452 [0x7f6cc67fc700] ERROR - XML: parser^@
Oct 17, 2019 00:35:23.452 [0x7f6cc67fc700] ERROR - XML: Extra content at the end of the document^@
Oct 17, 2019 00:35:23.452 [0x7f6cc67fc700] ERROR - XML: </MPD>^@
Oct 17, 2019 00:35:23.452 [0x7f6cc67fc700] ERROR - Error parsing content.
Oct 17, 2019 00:35:23.452 [0x7f6cc67fc700] ERROR - Exception handled: Error parsing file
I’ve removed the DVR and re-added it multiple times to no avail. Any help would be appreciated!
I just resolved this for myself. I was using xTeVe 1.4.4 and migrating to 2.1.0 seems to have fixed my problem. Hopefully this helps some of you resolve this issue if you are encountering it.
