Live TV & DVR not working in Plex Mac w/ 1.18.0.1846
Server Version#:1.18.0.1846
Player Version#: 1.3.1.916
Going to live tv & DVR just comes up with error.
I confirm I am also seeing this issue, same versions as OP, my PMS is on a Shield TV. Only affects the Plex app, live TV is still working via web browser and “old” Plex Player app.
Same issues for me as well. I have all the same versions as well. However it does work fine for web client 4.8.3 though.
Same issue here.
I just noticed I’m having the same problem, same versions.
Anyone able to provide server and client logs?
Also having an error. same server and client versions (and on Mac OSX)
Same problem here and I’m not using a Mac, so the problem is not Mac specific. I get “There was an unexpected error. Please visit our forums if you continue to experience problems.” Server is Linux, player is Windows (new Plex app). Same versions as you. It worked fine in previous versions. I can access Live TV & DVR via other clients or web interface.
Yep, I’m having the same problem. I’m using a Mac mini for the server withHDHomeRun. PMP and Plex Web work fine on my macbook client, but the Plex Mac app gives the same errors as described above by others when trying to use the DVR feature (although I can access DVR setup via Settings/Live TV& DVR tabs).
same… logs attached
Plex Media Server Logs_2019-10-08_15-24-04.zip (3.6 MB)
Same problem.
Plex for Windows version 1.3.1.916
Server version 1.18.0.1906
@TxDigi Thanks for the log, I have reported to the devs…
This should be fixed in the next release which is coming soon-ish…(but probably not before the weekend).
If you are desperate to use it, the old Plex Media Player still works for Live TV and DVR
Which can be downloaded from here as needed: Plex Media Player
A preview release is available if you want to test it:
seems to have fixed the unexpected error in Live TV !!!
I concur the Live TV issues appear to be fixed
Here we go with issues again in build .1973
OK, but that’s a beta, so reporting it properly should hopefully get it fixed before it goes into production.
