Server Version#: 1.29.1.6316
Player Version#: 1.29.1.6316 (Android TV / Google TV)
Tuner Make/Model: HDHomeRun and Hauppauge (both see issues)
Guide/Lineup name: Plex EPG
Using XMLTV?: No
Channel number/Name: All
My Live TV & DVR playback is now extremely unstable after the latest update - 1.29.1.6316. I believe this is the server side update, as my AndroidTV client started seeing this issue after the server update. Updating the Android client to 1.29.1.6316 did not resolve the issue.
Issue: Playback stops randomly acting like it’s buffering, and then eventually crashes stating playback was stopped. I will try to grab the exact error message in the morning. Playback will work again if I select the channel again, but will crash out anywhere between 30 seconds to 10 minutes. I’ve tried different tuners covering different stations from different markets, and it does not appear to be a weak TV signal issue, nor is it related to either a Hauppauge or HD HomeRun tuner.
Earlier today, I saw it crash out on a recorded movie after about 30 minutes, but haven’t been able to replicate that since.
Is anyone else experiencing this? I can submit server-side logs if that would be helpful.
