Live TV is broken
Ever since the release of Plex Experience, I have been unable to get live TV to work. I used HDHomerun TV tuners and a 2018 Mac Mini as my server. I have been forced to downgrade my server version to get it to work. No release, beta or otherwise, has worked. When I try to watch live TV, nothing happens, like the tuners are offline, but they are not. This Plex experience is not a great experience.
Plex Media Server Logs_2025-05-28_15-30-42.zip (4.7 MB)
Can I get some help with this?
Networking issue:
May 28, 2025 15:30:00.813 [0x70000465b000] ERROR - [Req#26acb/Transcode/4e92f4f0-36d7-4903-b556-115ec182cc3c/c7b10aeb-c0d1-4a33-8036-cc988d9f8bc8] [tcp @ 0x7fdbf0f04340] Connection to tcp://192.168.50.147:5004 failed: No route to host
May 28, 2025 15:30:00.814 [0x70000465b000] ERROR - [Req#26acc/Transcode/4e92f4f0-36d7-4903-b556-115ec182cc3c/c7b10aeb-c0d1-4a33-8036-cc988d9f8bc8] http://192.168.50.147:5004/auto/v25.1: No route to host
Likely because you have two ip’s on same lan segment.
May 28, 2025 15:05:21.394 [0x700004867000] DEBUG -  * 4 en0 (fdd3:602c:a4a1:cb4e:107e:3674:9113:37c0) (F0-18-98-EA-74-C2) (loopback: 0)
May 28, 2025 15:05:21.394 [0x700004867000] DEBUG -  * 4 en0 (192.168.50.124) (F0-18-98-EA-74-C2) (loopback: 0)
May 28, 2025 15:05:21.394 [0x700004867000] DEBUG -  * 7 en1 (192.168.50.249) (A6-D4-79-89-38-83) (loopback: 0)
May 28, 2025 15:05:21.394 [0x700004867000] DEBUG -  * 7 en1 (fdd3:602c:a4a1:cb4e:473:dc20:16f8:e1fd) (A6-D4-79-89-38-83) (loopback: 0)
If you could narrow down the time and title of the failure it would help say more accurately what the issues is. Broadly you have naming issues, transcoder failures from badly formatted files, XVID and AVI files, slow database queries.
In the versions after v1.41.5.9522-a96edc606 was a bug that bloated your database file and the fix is in 1.41.8.9834.
I did not know that there was a version 1.41.8.9834. I will try to update and see if that fixes it.
This issue is only with my live tv streams and DVR recordings. I do not have any issues with the rest of my database.
I updated and tried that version with the same issue.
Did you remove the second ethernet? Two adapters on the same segment will cause intermittent issues.
Fresh logs to confirm but:
The HDHR5-4US & HDFX-4K are reporting “No route to host”. Rebooting the HDHR’s and router couldn’t hurt to clear any bad host caching.
