Live TV lags - Wasn't the case a few days ago
A few days ago, Live TV worked very well and the transmission quality was excellent. Without changing the configuration (same antenna and same Hauppauge device), the live TV stream is lagging from time to time. As if the signal was bad. Still, the signal strength is between 95% and 100%. Moreover, with the WinTV Hauppauge application, the quality is excellent. Without being sure, this seems related to a recent update of the Plex server that I applied (under Windows). Possible? I really do not know what to do?
I’m getting intermittent pixelation in the live tv stream since implementing the same update (updated to 1.15.2.793 earlier this week; this morning updated to 1.15.3.876 and the problems persists). Just like you, viewing through the WinTV application does not suffer from that problem. These may be related issues.Plex Media Server Logs_2019-04-06_10-09-01.zip (4.1 MB)
Will someone with Plex please comment on this problem?
I still have the problem and I’m waiting for a solution as well.
