Not working ![]()
Jul 23, 2017 14:43:20.664 [9560] INFO - * tvs_program_streamer::tuning_thread. Finished tuning thread for program triplet://8808:2:3
Jul 23, 2017 14:43:20.778 [12848] INFO - * CTSStreamWaiter::GetPidToCheck. PID to check 102
Jul 23, 2017 14:43:20.778 [12848] INFO - * CTSStreamWaiter::GetVideoPid. Video PID 102
Jul 23, 2017 14:43:20.826 [12848] INFO - * CTSStreamWaiter::ProcessStream. Found first not encrypted packet. Start streaming
Jul 23, 2017 14:44:20.971 [13032] WARN - [E] http_streamer_t: http write error
Jul 23, 2017 14:44:20.971 [6860] INFO - * http_streamer_t::send_thread_func: removing http client
Jul 23, 2017 14:44:20.972 [6860] INFO - * http_streamer_t::send_thread_func: all clients are deleted. Setting exit flag
Jul 23, 2017 14:44:20.974 [11348] INFO - * streamer_container_t::control_thread. Removed disconnected streamer 754ef0a5-711a-42b7-ba54-c26dbdb280ce
Jul 23, 2017 14:44:20.975 [11348] INFO - * streamer_container_t::delete_streamer. Last streamer was deleted. Stop program streamer
Jul 23, 2017 14:44:20.975 [11348] INFO - * dvb_program_streamer_t::stop. Stoping program streamer for channel triplet://8808:2:3
Jul 23, 2017 14:44:20.975 [11348] INFO - * transponder_streamer::stop_channel. Stop request for channel triplet://8808:2:3
Jul 23, 2017 14:44:20.986 [12848] INFO - * CTVSStreamSource::RemoveAllPids. Removing PIDs for client triplet://8808:2:3
Jul 23, 2017 14:44:20.986 [11348] INFO - * transponder_streamer::start_idle_timer
Jul 23, 2017 14:44:25.378 [4832] INFO - * device_manager_t::idle_timer_func. Stream container for channel triplet://8808:2:3 on device dvb#bda#0#@device:pnp:\?\usb#vid_2040&pid_0264#0013802617#{71985f48-1ca1-11d3-9cc8-00c04f7971e0}{7c8095ab-c110-40e5-9f4d-310858bbbf64} is idle. Deleting it.
Jul 23, 2017 14:44:30.013 [1240] INFO - * Stopping graph
Jul 23, 2017 14:44:30.026 [12848] INFO - * StopDevice()
Jul 23, 2017 14:44:30.296 [12848] INFO - * stop_graph: hr=0, state=0
Jul 23, 2017 14:44:30.400 [4832] INFO - * device_manager_t::idle_timer_func. Device dvb#bda#0#@device:pnp:\?\usb#vid_2040&pid_0264#0013802617#{71985f48-1ca1-11d3-9cc8-00c04f7971e0}{7c8095ab-c110-40e5-9f4d-310858bbbf64} is idle. Unloading it.
Jul 23, 2017 14:44:30.400 [4832] INFO - * transponder_streamer::stop_idle_timer
Post the complete logs from the Android device and the Plex Server after rebooting the phone/tablet/etc and restarting the Plex Server software, waiting two minutes, and then initiating a Live TV viewing on the Android device.
And what you think about my problem ?
Jul 23, 2017 16:18:34.580 [1084] ERROR - Unable to find title for item of type 5
Jul 23, 2017 16:18:34.580 [1084] DEBUG - MDE: analyzing media item -1
Jul 23, 2017 16:18:34.580 [1084] DEBUG - MDE: : no direct play video profile exists for http/mpegts/
Jul 23, 2017 16:18:34.580 [1084] DEBUG - MDE: : no direct play video profile exists for http/mpegts//
Jul 23, 2017 16:18:34.581 [1084] DEBUG - MDE: : codec is unavailable for analysis
Jul 23, 2017 16:18:34.581 [1084] ERROR - Unable to find title for item of type 5
Jul 23, 2017 16:18:34.581 [1084] DEBUG - MDE: : selected media 0 / -1
Jul 23, 2017 16:18:34.582 [1084] DEBUG - Cleaning directory for session 3deff473-1bd3-4361-a50b-6eceb778177a ()
Jul 23, 2017 16:18:34.582 [1084] DEBUG - Starting a transcode session 3deff473-1bd3-4361-a50b-6eceb778177a at offset -1.0 (state=3)
Jul 23, 2017 16:18:34.582 [1084] DEBUG - Streaming Resource: Added session 05AF4290:3deff473-1bd3-4361-a50b-6eceb778177a
Jul 23, 2017 16:18:34.585 [1084] DEBUG - Job running: EAE_ROOT=‘\?\H:\Plex Media Server\Cache\Transcode\Sessions\EasyAudioEncoder’ FFMPEG_EXTERNAL_LIBS=‘\\?\H:\Plex\ Media\ Server\Codecs\46b03cf-1241-windows-i386\’ XDG_CACHE_HOME='H:\Plex Media Server\Cache' XDG_DATA_HOME='C:\Program Files (x86)\Plex\Plex Media Server\Resources' X_PLEX_TOKEN=‘xxxxxxxxxxxxxxxxxxxx’ C:\Program Files (x86)\Plex\Plex Media Server\PlexTranscoder.exe -noaccurate_seek -ignore_unknown -scan_all_pmts -1 -i http://127.0.0.1:32600/devices/compound_device041dvb%23bda%23usb%23vid_2040%26pid_0264%230013802617%23/media/triplet%3A%2F%2F8808%3A2%3A3?param=<%3Fxml%20version%3D"1.0"%20encoding%3D"UTF-8"%3F> <tunedata><tt>4<%2Ftt><dq>0<%2Fdq><dr%2F><fr>498000<%2Ffr><md>0<%2Fmd><sr>0<%2Fsr><pl>0<%2Fpl><lf>8<%2Flf><l1>0<%2Fl1><l2>0<%2Fl2><ls>0<%2Fls><pp>0<%2Fpp><hz>0<%2Fhz><in>0<%2Fin><fc>0<%2Ffc><t>2<%2Ft><n>8808<%2Fn><s>3<%2Fs><en>0<%2Fen><%2Ftunedata> -map 0:V? -codec:V copy -map 0:a? -codec:a copy -copypriorss:a 0 -map 0:s? -codec:s copy -segment_format mpegts -f ssegment -individual_header_trailer 0 -segment_time 1 -segment_start_number 0 -segment_copyts 1 -segment_time_delta 0.0625 -segment_list http://127.0.0.1:32400/video/:/transcode/session/3deff473-1bd3-4361-a50b-6eceb778177a/e547a2f0-e3f6-4520-94d0-0e26c564f7af/seglist -segment_list_type csv -segment_list_size 2147483647 -max_delay 5000000 -avoid_negative_ts disabled -map_metadata -1 -map_chapters -1 media-%05d.ts -start_at_zero -copyts -vsync cfr -y -nostats -loglevel quiet -loglevel_plex error -progressurl http://127.0.0.1:32400/video/:/transcode/session/3deff473-1bd3-4361-a50b-6eceb778177a/e547a2f0-e3f6-4520-94d0-0e26c564f7af/progress
Jul 23, 2017 16:18:37.580 [9972] DEBUG - Activity: updated activity 92d3b31c-c742-4785-9ed8-ca8ac73196e2 - completed 1% - Recording
Jul 23, 2017 16:18:40.582 [13052] DEBUG - Activity: updated activity 92d3b31c-c742-4785-9ed8-ca8ac73196e2 - completed 2% - Recording
Jul 23, 2017 16:18:42.111 [10224] DEBUG - Auth: We found auth token (xxxxxxxxxxxxxxxxxxxx), enabling token-based authentication.
Jul 23, 2017 16:18:42.111 [10224] DEBUG - Auth: Came in with the master token, authorization succeeded.
Jul 23, 2017 16:18:42.111 [0324] DEBUG - Request: [127.0.0.1:53578 (Loopback)] PUT /video/:/transcode/session/3deff473-1bd3-4361-a50b-6eceb778177a/e547a2f0-e3f6-4520-94d0-0e26c564f7af/progress/stream?index=1&id=102&codec=h264&type=video (13 live) Signed-in Token (genosajd)
Jul 23, 2017 16:18:42.111 [5348] DEBUG - Completed: [127.0.0.1:53578] 206 PUT /video/:/transcode/session/3deff473-1bd3-4361-a50b-6eceb778177a/e547a2f0-e3f6-4520-94d0-0e26c564f7af/progress/stream?index=1&id=102&codec=h264&type=video (13 live) 1ms 227 bytes
Jul 23, 2017 16:18:42.111 [5296] DEBUG - Request: [127.0.0.1:53579 (Loopback)] PUT /video/:/transcode/session/3deff473-1bd3-4361-a50b-6eceb778177a/e547a2f0-e3f6-4520-94d0-0e26c564f7af/progress/stream?index=2&id=103&codec=mp3&type=audio (14 live) Signed-in Token (genosajd)
Jul 23, 2017 16:18:42.111 [5348] DEBUG - Completed: [127.0.0.1:53579] 206 PUT /video/:/transcode/session/3deff473-1bd3-4361-a50b-6eceb778177a/e547a2f0-e3f6-4520-94d0-0e26c564f7af/progress/stream?index=2&id=103&codec=mp3&type=audio (14 live) 1ms 227 bytes
Jul 23, 2017 16:18:42.111 [5348] DEBUG - Auth: We found auth token (xxxxxxxxxxxxxxxxxxxx), enabling token-based authentication.
Jul 23, 2017 16:18:42.111 [5348] DEBUG - Auth: Came in with the master token, authorization succeeded.
Jul 23, 2017 16:18:42.111 [0324] DEBUG - Request: [127.0.0.1:53580 (Loopback)] PUT /video/:/transcode/session/3deff473-1bd3-4361-a50b-6eceb778177a/e547a2f0-e3f6-4520-94d0-0e26c564f7af/progress/stream?index=3&id=104&codec=eac3&type=audio (15 live) Signed-in Token (genosajd)
Jul 23, 2017 16:18:42.127 [10224] DEBUG - Completed: [127.0.0.1:53580] 206 PUT /video/:/transcode/session/3deff473-1bd3-4361-a50b-6eceb778177a/e547a2f0-e3f6-4520-94d0-0e26c564f7af/progress/stream?index=3&id=104&codec=eac3&type=audio (15 live) 1ms 227 bytes
Jul 23, 2017 16:18:42.127 [10224] DEBUG - Auth: We found auth token (xxxxxxxxxxxxxxxxxxxx), enabling token-based authentication.
Jul 23, 2017 16:18:42.127 [10224] DEBUG - Auth: Came in with the master token, authorization succeeded.
Jul 23, 2017 16:18:42.127 [5296] DEBUG - Request: [127.0.0.1:53581 (Loopback)] PUT /video/:/transcode/session/3deff473-1bd3-4361-a50b-6eceb778177a/e547a2f0-e3f6-4520-94d0-0e26c564f7af/progress/stream?index=4&id=108&codec=eac3&type=audio (15 live) Signed-in Token (genosajd)
Jul 23, 2017 16:18:42.127 [5348] DEBUG - Completed: [127.0.0.1:53581] 206 PUT /video/:/transcode/session/3deff473-1bd3-4361-a50b-6eceb778177a/e547a2f0-e3f6-4520-94d0-0e26c564f7af/progress/stream?index=4&id=108&codec=eac3&type=audio (15 live) 1ms 227 bytes
Jul 23, 2017 16:18:42.143 [0324] ERROR - [Transcoder] [h264 @ 03458380] non-existing SPS 0 referenced in buffering period
Jul 23, 2017 16:18:42.143 [5296] ERROR - [Transcoder] [h264 @ 03458380] SPS unavailable in decode_picture_timing
Jul 23, 2017 16:18:42.143 [0324] ERROR - [Transcoder] [h264 @ 03458380] non-existing PPS 0 referenced
Jul 23, 2017 16:18:42.143 [5296] ERROR - [Transcoder] [h264 @ 03458380] non-existing SPS 0 referenced in buffering period
Jul 23, 2017 16:18:42.143 [0324] ERROR - [Transcoder] [h264 @ 03458380] SPS unavailable in decode_picture_timing
Jul 23, 2017 16:18:42.143 [5296] ERROR - [Transcoder] [h264 @ 03458380] non-existing PPS 0 referenced
Jul 23, 2017 16:18:42.143 [0324] ERROR - [Transcoder] [h264 @ 03458380] decode_slice_header error
Jul 23, 2017 16:18:42.158 [5296] ERROR - [Transcoder] [h264 @ 03458380] no frame!
Jul 23, 2017 16:18:42.158 [0324] ERROR - [Transcoder] [h264 @ 03458380] non-existing SPS 0 referenced in buffering period
Jul 23, 2017 16:18:42.158 [5296] ERROR - [Transcoder] [h264 @ 03458380] SPS unavailable in decode_picture_timing
Jul 23, 2017 16:18:42.158 [0324] ERROR - [Transcoder] [h264 @ 03458380] non-existing PPS 0 referenced
Jul 23, 2017 16:18:42.174 [5296] ERROR - [Transcoder] [h264 @ 03458380] non-existing SPS 0 referenced in buffering period
Jul 23, 2017 16:18:42.174 [0324] ERROR - [Transcoder] [h264 @ 03458380] SPS unavailable in decode_picture_timing
Jul 23, 2017 16:18:42.174 [5296] ERROR - [Transcoder] [h264 @ 03458380] non-existing PPS 0 referenced
Jul 23, 2017 16:18:42.174 [0324] ERROR - [Transcoder] [h264 @ 03458380] decode_slice_header error
Jul 23, 2017 16:18:42.189 [5296] ERROR - [Transcoder] [h264 @ 03458380] no frame!
Jul 23, 2017 16:18:42.189 [0324] ERROR - [Transcoder] [h264 @ 03458380] non-existing SPS 0 referenced in buffering period
Jul 23, 2017 16:18:42.189 [5296] ERROR - [Transcoder] [h264 @ 03458380] SPS unavailable in decode_picture_timing
Jul 23, 2017 16:18:42.189 [0324] ERROR - [Transcoder] [h264 @ 03458380] non-existing PPS 0 referenced
Jul 23, 2017 16:18:42.189 [5296] ERROR - [Transcoder] [h264 @ 03458380] non-existing SPS 0 referenced in buffering period
Jul 23, 2017 16:18:42.189 [0324] ERROR - [Transcoder] [h264 @ 03458380] SPS unavailable in decode_picture_timing
Jul 23, 2017 16:18:42.189 [5296] ERROR - [Transcoder] [h264 @ 03458380] non-existing PPS 0 referenced
Jul 23, 2017 16:18:42.189 [0324] ERROR - [Transcoder] [h264 @ 03458380] decode_slice_header error
Jul 23, 2017 16:18:42.205 [0324] ERROR - [Transcoder] [h264 @ 03458380] non-existing PPS 0 referenced
Jul 23, 2017 16:18:42.205 [5296] ERROR - [Transcoder] [h264 @ 03458380] non-existing SPS 0 referenced in buffering period
Jul 23, 2017 16:18:42.205 [0324] ERROR - [Transcoder] [h264 @ 03458380] SPS unavailable in decode_picture_timing
Jul 23, 2017 16:18:42.205 [5296] ERROR - [Transcoder] [h264 @ 03458380] non-existing PPS 0 referenced
Jul 23, 2017 16:18:42.205 [0324] ERROR - [Transcoder] [h264 @ 03458380] decode_slice_header error
Jul 23, 2017 16:18:42.205 [5296] ERROR - [Transcoder] [h264 @ 03458380] no frame!
Jul 23, 2017 16:18:42.205 [0324] ERROR - [Transcoder] [h264 @ 03458380] non-existing SPS 0 referenced in buffering period
Jul 23, 2017 16:18:42.205 [5296] ERROR - [Transcoder] [h264 @ 03458380] SPS unavailable in decode_picture_timing
Jul 23, 2017 16:18:42.346 [0324] ERROR - [Transcoder] [h264 @ 03458380] non-existing SPS 0 referenced in buffering period
Jul 23, 2017 16:18:42.346 [5296] ERROR - [Transcoder] [h264 @ 03458380] SPS unavailable in decode_picture_timing
Jul 23, 2017 16:18:42.361 [0324] ERROR - [Transcoder] [h264 @ 03458380] non-existing PPS 0 referenced
Jul 23, 2017 16:18:42.361 [5296] ERROR - [Transcoder] [h264 @ 03458380] non-existing SPS 0 referenced in buffering period
Jul 23, 2017 16:18:42.361 [0324] ERROR - [Transcoder] [h264 @ 03458380] SPS unavailable in decode_picture_timing
Jul 23, 2017 16:18:42.361 [5296] ERROR - [Transcoder] [h264 @ 03458380] non-existing PPS 0 referenced
Jul 23, 2017 16:18:42.377 [0324] ERROR - [Transcoder] [h264 @ 03458380] decode_slice_header error
Jul 23, 2017 16:18:42.377 [5296] ERROR - [Transcoder] [h264 @ 03458380] no frame!
Quite a few errors regarding the DVR and transcoding.
and I can only wait for next update?
@genosajd I would say yeah, wait for the next update, its beta for a reason
What Android device is that?
galaxy note 4, android 6
Might be an issue with Marshmallow and the Plex app. Hopefully a Plex team member/ninja can take a look.
Try selecting use android media player under settings - advanced - player
Yes, on external player like MX player live tv is working
Seems to be an issue with the decoding engine within Plex App and running on Marshmallow. Had a similar issue on my Galaxy S5. Made those changes in the Plex app and it now works. Did not have the issue on a Galaxy Tab S2 which is running Nougat although playback was a bit choppy. Changed to use “Android Media Player” on the Tab S2 and the choppy streaming disappeared. Its a first Beta so I can live with it
after update, still not working
