How do I do this? Same issue with DVB-T mpeg4 in Ireland. 16:9 displays as 4:3 when watching live. Recorded or transcoded programs are fine.
@DaveBinM. Please help! What exactly do you need please?
The problem is STILL occurring with latest version of Android TV App on both of my Sony TVâs.
I can get all new logs and screenshots but the last time I never received feedback. See my post above (Live TV: SD channels render incorrectly as 4:3) where I posted all logs back on November.
Here in New Zealand, the âhome learningâ channel set up for our kids during lockdown is in SD. So the picture is squashed to 4:3.
Thanks, Elton.
Hi @DaveBinM,
Raw sample capture attached from my transcode cache:
media-00138.zip (172.5 KB)
Client Log:
200425_PlexClient.zip (122.0 KB)
Relevant details from client log:
04-25 17:33:14.975 i: [FFmpeg] [ERROR] [NULL @ 0x6ea78800] SPS unavailable in decode_picture_timing
04-25 17:33:14.975 i: [FFmpeg] [ERROR] [NULL @ 0x6ea78800] non-existing PPS 0 referenced
04-25 17:33:15.089 i: [FFmpeg] [WARN] [NULL @ 0x6ea78800] ignoring invalid SAR: 16/11
04-25 17:33:16.928 i: [Exo2VideoPlayer] Video size is now 720x576
04-25 17:33:16.929 i: [video] Video size is now 720x576 (ratio: 1.00)
04-25 17:33:16.933 i: [video] Transcoding anamorphic content, using original video size (720x576)
04-25 17:33:16.937 i: [video] Scaling video view to 1350x1080
04-25 17:33:16.940 i: [VideoOverlay] Video player size changed (1350, 1080)
04-25 17:33:16.942 i: [Exo2VideoPlayer] Drawn to surface detected.
04-25 17:33:16.942 i: [video] Video start detected
04-25 17:33:16.987 i: [video] Video has started.
04-25 17:33:16.987 i: Fetching [method:GET] https://192.168.100.10:32400/:/timeline?duration=5873&guid=tv.plex.xmltv%3A%2F%2Fepisode%2FThe%2520Amazing%2520Race%2520Australia%2F4%2F3&key=%2Flivetv%2Fsessions%2F2066fe8d-2dcb-4f2e-9946-5ba35af44ef1&playbackTime=0&playQueueItemID=0&ratingKey=25058&state=playing&time=0&token=...5z-Y&X-Plex-Client-Identifier=c239a0a961ce76c1-com-plexapp-android&X-Plex-Token=...5z-Y
04-25 17:33:16.988 i: [TranscodeSession] Updating session status
04-25 17:33:17.024 i: [Exo2VideoPlayer] Passing subtitle offset of 0.
04-25 17:33:17.041 i: [BatteryBehaviour] Warning: results not reliable since device is connected to power.
04-25 17:33:17.079 i: [TranscodeSession] Direct Play
Details from MediaInfo:
ID/String : 256 (0x100)
MenuID/String : 1 (0x1)
Format/String : AVC
Format/Info : Advanced Video Codec
Format_Profile : High@L3
Format_Settings : CABAC / 4 Ref Frames
Format_Settings_CABAC/String : Yes
Format_Settings_RefFrames/String : 4 frames
CodecID : 27
Duration/String : 40 ms
Width/String : 720 pixels
Height/String : 576 pixels
DisplayAspectRatio/String : 16:9
FrameRate/String : 25.000 FPS
Standard : Component
ColorSpace : YUV
ChromaSubsampling/String : 4:2:0
BitDepth/String : 8 bits
ScanType/String : Interlaced
ScanType_StoreMethod/String : Separated fields
ScanOrder/String : Top Field First
colour_range : Limited
colour_primaries : BT.601 PAL
transfer_characteristics : BT.470 System B/G
matrix_coefficients : BT.470 System B/G
Please let me know if you need any more testing, logs, anything. This is driving me crazy and Iâm clearly not the only one with issues. All other clients are fine except my 2x Android TVâs.
Thanks, Elton.
Can you provide a longer sample, say a minute or two? That sample is tiny
Hi @DaveBinM.
Sorry, my notifications were going to my junk folder. I focused my efforts on getting the ânew playerâ (see below) and finally managed to get that working. Once the new player was working the problem was fixed so it appeared to be related to the older player.
If anyone else has this issue, I recommend focusing on getting the new player working (see below) as its much more responsive and more likely to be supported in future.
