The setting for live TV and DVR has disappeared from my settings on my Plex server.
Is it temporary?
My Plex pass is up to date .
thanks,
John
Did you perform a factory reset on a nVidia Shield? If so, the ancient Plex version that comes by default doesn’t support DVR , yet.
You need to update the Plex server software version.
It worked. reset my Nvida shield.
All is is good.
Thank you!!
My issue has returned.
I cant get live TV DVR to show up in web setting.
Also, now when I scan my movies libraries the movies don’t show up.
I reset my Nvidia shield and Fire TV Devices many times.
Each time I do the reset It
- links my account and shows the new server at the web config page
but with no live TV.
My Plex pass is active.
Something not linking the Plex pass to my server??
Help,
John
If you reset your Shield device, it will throw away the Plex server update and revert to a software version without Live TV support.
See above.
As @OttoKerner was saying the default version 1.4.3 installed after a reset does not have Live TV & DVR. You need to go to the Google Play Store, sign-in and install the current version.
