LiveTV stopping, 5.1/H264 transcoding issues, guide loading and player crashing
Server Version#: 1.41.8.9834
Player Version#: Latest NVIDIA Shield Pro non-beta
Tuner Make/Model: HDHomeRun
Guide/Lineup name: ?
Using XMLTV?: No
Channel number/Name: All
l have been having multiple issues with LiveTV on my setup, some of them for quite a while. I’ve decided to attempt to log them here so they could be potentially resolved. If more information is required, then I am happy to do what is required in order to get them resolved:
  1. Advert breaks or change of program often causes a swirling circle, sometimes the program will recover and continue playing after a short time, sometimes it will just stop with an error. I have all advert detection switched off.
  2. When watching any program with 5.1 sound (AAC_LATM) it will re-encode to Opus, which I’m fine with as the Shield apparently does not support it. However, it also reencodes the video to a 1080p/25 signal, which means sport is no longer smooth. Can this be resolved either by not transcoding video or transcoding with interlacing remaining?
  3. I have a favourites list in my guide, but the top channel in this list does not load guide items on entering the guide. If I scroll down a few channels to push the failing channel off the top of the screen, then go back up, the items for that channel appear.
  4. Sometimes (but not repeatable) scanning too quickly forward or backward, the player will stay on the swirling circle and never return to the video output. If I kill the plex client and restart NO videos work. Videos only start working again if I restart the Shield
Because of these 4 issues above, LiveTV can be an infuriating experience. Please could you please look into it. None of the issues above are new to the version of the server or client, they have been around for a while.
I had similar issues starting around May. My server was constantly crashing, my LiveTV stopped (due to server crashing), most recordings failed, etc. I used the utility found here GitHub - ChuckPa/DBRepair: Database repair utility for Plex Media Server databases to fix the database and ever since then, I haven’t had any issues.
