Server Version#: 1.15.6.1079
Player Version#: 3.102.0
Howedy all,
I’ve been unable to get local lyrics working for some time now. I have several artists who’s lyrics are not available in LyricFind. I rather enjoy the timed lyrics, and used a generator to create the .lrc files. When placed in the album’s directory, Plex doesn’t show as the lyrics are available.
[00:42.38]I know, you know I’ve been waiting
[00:47.56]Sleepless nights, no conversations
[00:53.16]And I know you had a clue but faked it
[00:58.76]The innocence in your eyes, I hate it
[01:03.71]My soul, so low
[01:06.63]Need you gone
I’ve done a bit of digging, but haven’t found any good solutions to this issue
Hmmm…I decided to mess about a bit based on what you posted, manually adding in the timestamps and then changed the .txt to .lrc and the lyrics are showing as well as highlighting the lyrics as it goes.
So perhaps it is either you need to manually refresh the metadata or else something going on with the program?
Not sure if this makes a difference but I am on version 1.15.8.1198 of the server.
I know in the past I would have times when I had no lyrics and needed to do a ‘Refresh All Metadata’ (i.e. the global library option) for it to work. I also set my agents as follows (though this shouldn’t have an impact on your case since this was a LyricFind issue for me at the time):
The thing with this though is depending on how large your library is, it can be very time consuming (for me it takes many many hours so I usually kick it off before going to bed )
Perhaps it is in the way that the folder and file structure is that is preventing Plex from finding the lyric files? At this point I am not sure why it would not be working for you
I won’t lie to you, I’ve actually spent a few weeks messing with this on and off. Renaming files (removing the track number, etc), trying to get this to work.
I left for a meeting, and when I returned, the timed lyrics showed up perfectly. Verified on three different songs.
I’m guessing the “Refreshing Metadata” took a bit longer than the web interface lead on with.
Either way, all is fixed, and I’m as happy as can be! Thank you sir/madem!
