Lyrics Not Showing
I am a Plex Pass subscriber and had previously been able to view the Lyrics for most of my Music content. At some point in the past 4-5 Months I no longer have the button to show the Lyrics. This is from the Web Player as well as Android Player. I know I have the ‘Premium’ Music selected for the library.
Any ideas what the issue is?
It’s gone for me now too, even though I use my own .lrc files. The Button is greyed out.
I have Lyrics, both from Lyricfind and from local .lrc files, working on my server, so you’re probably looking at a configuration issue, or at worst, possibly a corrupt database.
Couple of dumb questions, cuz, y’know, you never know:
  1. Are you certain you are looking at the same tracks, on the same albums, where lyrics worked in the past? I ask because I found that Lyricfind seems to be organized by album only, so if a track appears on an original album, and a “various artists” album, you might get lyrics in one case, but not the other.
  2. If you’re using local .lrc files, are you certain the filenames still match? Nothing has renamed the .mp3, but not the .lrc?
After that, someone else will need to chime in, but they’ll probably want to see log files, and the following:
Plex server OS
Plex Server version number
Plex Web version number
Ok I just figured out that only some albums don’t work for me. I had problems with subtitles in the past, but since I’m moving my server onto a differnt machine in the near future I will wait until then with persuing this problem.
Is there a way to disable the lyricfind service or force local lyrics? In the past when the service was down I couldn’t use my local ones.
You can disable the Lyricfind agent in your Server settings. I have no idea if that still allows local lyric files to be used, though.
Lyric find is enabled. It is number3 ordered agent for Albums.
Server 2012r2 fully patched
Plex 1.3.3.3148
Web 2.12.5
Thanks for the help.
What logs would be beneficial to assist in troubleshooting this? I killed my Music library and have only added in 5 Albums. I have only gotten Lyrics for 1 song in 1 of the Albums.
Any further help would be appreciated. Thanks.
