Cool, thanks!
Messy in terms of the names being displayed and the order?
Cool, thanks!
Yes… it’ll be an assorted dump of all show/season/episode extras – though based on your previous statement about not categorizing them, that might be ok for you.
Cool, thanks!
Yeah, that’s plenty fine for now. If/when season level works in the other apps I might switch back to season level.
Thanks for all your assistance on this!
I am using Plex server 1.24.4.5081. Trying on Plex Web (on my PC) 4.63.0, and iOS app 7.24. I have a lifetime Plex Pass, and have checked that “Find extras” setting for the Plex TV Series agent is turned On.
The extras don’t show up in either client when I try both these ways of storing them:
You are not adding the file correctly.
I have been trying to manage extras at the episode level (for iOS). I have been able to get the extras to show up at the season level but can’t get it to work at the episode level. In my case I have two featurettes (with “-featurette1” and “-featurette2”) for an episode). When I have the files inline in the season folder (“Show -SXXEXX - Episode Name-featurette1”) it is not working. Am I missing something?
Make sure the base name of those extras is an exact match of the episode file name.
Example:
TV Shows
Futurama (1999)
Season 06
Futurama (1999) - s06e01 - Rebirth.ext <- the episode
Futurama (1999) - s06e01 - Rebirth-deleted1.ext <- 1st deleted scene
Futurama (1999) - s06e01 - Rebirth-deleted2.ext <- 2nd deleted scene
In the meantime you can also give those inline episode extras their own title and include it in the filenames:
TV Shows
Futurama (1999)
Season 06
Futurama (1999) - s06e01 - Rebirth - 1. Alternate Opening (used for original U.S. broadcast)-deleted.ext <- deleted scene "1. Alternate Opening (used for original U.S. broadcast)"
Futurama (1999) - s06e01 - Rebirth - 2. I'd Like to Build a Bot-deleted.ext <- deleted scene "2. I'd Like to Build a Bot"
Also make sure to refresh the episode/show metadata after changing your extra file names.
Thank you for the reply. I had been keeping the season and episode numbers matching but not the title before the “-extras” extension. I have it fixed now.
