Server Version#:1.20.4.3517
I have been advised that you should not store PLEX Media under the “Multimedia” folder on the NAS.
So, I need to no the best way to move my media subfolders from that folder to a new unique folder.
Thanks!
Thanks!
The best approach is one where the shared folders make sense to you:
Two common techniques are often found:
/share/CACHEDEVx_DATA/
Media/
Movies/
Television/
Music/
Photos/
Whichever technique is easiest and most logical for you is best.
The only recommendation is to avoid that MultiMedia shared folder
If, because of how your drives are setup , you need “Movies” , “Movies2”, “Movies3”, then that’s OK too. Plex will simply merge all of them (“EDIT” the “movie” section library and add all the shared folders being used)
What tool or utility do I use to move the subfolders?
Thanks!
If you use the “File Station” on your NAS, the move will just take seconds.
Many Thanks!
