In the last week, or so, I have notified that when I open the Plex app on my AppleTV, it asks me to choose the user, rather than defaulting to my, admin, account. I used to be able to tell it that once I chose my ID, to remember that as the ID each time but I can’t find where that setting is anymore.
Did that get removed? Am I being blind?
Just to clarify, it knows my account but it shows the three other managed users’ ID so that I could choose them but, on this device, I do not want to even see their ID as an option. It should, used to, go straight into the UI without asking me to choose every time I open the app.
Should be in the main app settings which you should be able to access via the setting option in the side bar
log on as the admin user > settings within plex > remember last user (or something to that effect).
you must be in the admin profile to enable this, managed users can not set it
on plex web, for example, it looks like this
Thank you to you both. I knew how to do it in other apps and this was always, before, under the User ID at the top. Now the “Settings” is at the bottom of the libraries and I have a lot of libraries so I never made it all the way down to find it.
Thanks again…it’s the little things!!!
yeah, settings got moved, which is a bit confusing and annoying
