Logs are filled with WARN - NAT: PMP, timed out waiting for response
Server Version#: 1.42.2.10122
Player Version#: N/A
Log file is filled with:
WARN - NAT: PMP, timed out waiting for response.
NAT: PMP is not possible in the network, port is filled manually and the server is acessible remotely by manual configuration.
How can I disable the server trying to configure NAT automatically
You can’t.
Update: Actually, I believe that is Plex trying to set the remote access port using upnp. If you change pms to use a manually specified port, that should stop.
I did specify a port manually but it does not stop unfortunately
Sorry. In that case I’m not sure what is causing that error.
Noticed the same warning today. Plex really needs to do better. Multiple issues with server and nobody listens.
I have manual port forward, and it should not even try to do UPnP because that is disabled.
