I hope someone can help me out. Right now I’m trying to share my server with plugins activated with some friends but for some reason the server wont come up at all. Plex will continues to display “Looking for servers”.
I’m able to access my server remotely on my phone and other computer using my account but unable to see it with my friends.
The server is being run on a Ubuntu 18.04 system.
Server Version#: Version 3.67.1
Player Version#: Version 1.13.8.5395
If you are accessing your server directly, you must also make sure it’s visible via Plex.tv (Remote Access) for them to see it else they will need to direct-in as well.
@ChuckPa - Thank you for the reply. I do have remote access setup and ready to go. How would they set direct access? There using an app to access my server. I know they tried it using a browser and the issue continues. I also tested the issue from a different browser on the same computer that has Plex server running and I got the same issue.
I am preparing to share 1.13.4 for you to confirm / try. It will tell me a lot.
If there is no difference, your DEBUG logs will be needed. (they will be needed anyway at some point)
I installed the file from the link and still nothing. How would I go about sending you the DEBUG logs? Also, how do I find the logs? I hope fixing this issue will also help with a new issue i’m having not displaying the plug-ins on the PS4 Plex app.
Since you can’t access the web app, please make a tar.gz of the Logs directory from the shell after restarting PMS and waiting about 3 minutes for it to get settled and attempting to talk to Plex.tv
Nov 08, 2018 15:48:24.354 [0x7fa506bff700] DEBUG - NetworkServiceBrowser: SSDP departed after not being seen for 27.148903 seconds: 192.168.1.194
Nov 08, 2018 15:48:25.944 [0x7fa506bff700] DEBUG - NetworkServiceBrowser: SSDP arrived: 192.168.1.194 (http://192.168.1.194:60000/upnp/dev/81a8c312-b10d-0de4-0000-0000094e79c7/desc)
Nov 08, 2018 15:48:25.945 [0x7fa500ffd700] DEBUG - HTTP requesting GET http://192.168.1.194:60000/upnp/dev/81a8c312-b10d-0de4-0000-0000094e79c7/desc
Nov 08, 2018 15:48:25.976 [0x7fa500ffd700] DEBUG - HTTP 200 response from GET http://192.168.1.194:60000/upnp/dev/81a8c312-b10d-0de4-0000-0000094e79c7/desc
Nov 08, 2018 15:48:38.474 [0x7fa50fffe700] DEBUG - handleStreamRead code 2: End of file
Nov 08, 2018 15:48:38.485 [0x7fa50fffe700] DEBUG - Auth: authenticated user 1 as maskmonkey
Nov 08, 2018 15:48:38.486 [0x7fa501fff700] DEBUG - Request: [127.0.0.1:50022 (Loopback)] GET /player/proxy/poll
Whatever is at that IP address keeps connecting and disconnecting (breaking) its connection to the server. It is the device itself (or Plex Player in it) which is connecting and disconnecting rapidly. The logs do not go into detail as to why it has disconnected.
Otherwise I do see streaming from the server to other devices.
Let’s take this step now for you to get control of the server again.
Close the browser completely
Open the browser
Open an In Cognito window
In that new window, open the IP address of the server directly (this loads the web client from it and ignores the fact you are already signed in to Plex.tv in the web account
I tried the steps and after testing it using a different account that I gave access to my plugins the issue continues.
I know this computer is using a USB Ethernet adapter to be able to get an internet connection. Maybe thats what is making it go crazy.
