Lost in Space vs Lost in Space 2018 When importing. The Plex Server adds both these TV series into same folders. They keep writing ontop of each other. I do try and fix match. With no luck.
Put the date in the show folder
You can also add the tvdb or tmdb id
Lost in Space (2018) {tvdb-343253}
Lost in Space (1965) {tvdb-72923}
Plex dance both shows
This is the way.
Your a Rock Star, thanks
