Hi, my internet connection dropped out about 1/2 way through updating a huge library, as such it appears that only 1/2 of the titles were matched. The other half appear to be unmatched titles with thumb shots of the footage.
Is there a way to bulk update/match the remaining library titles? I’ve tried to re-fresh metadata, but that doesn’t match the titles.
All the files are in a correctly named format and selecting individual entries and using the “match” or “fix match” feature works fine. but there’s over 2k entries to select (manually doing this is insane). I found a way to select all the entries, but there is no “fix match” option to fix them
Why does Plex server not allow to re-match when the db matching is clearly broken? and is there a way to bulk match? (or do I have to try my luck again and spend over a week wiping and re-doing the library files?)
