Hi yall
I’ve got two folders pointed at my Music library. I recently had to move one of them to cloud storage so followed the basic procedure
- Moved folder to cloud
- Turned off automatic trash deletion to prevent losing data
- Added new cloud folder from rclone mount
- Scanned. It seemed to recover/put everything in place but it then proceeded to do a sonic analysis. Annoying but whatever that took about a day and a half.
However now my waveforms while playing songs are missing from just files in those libraries. Rescan/scheduled task doesn’t seem to start anything. Files metadata/XML doesnt show loudness
Working file example
- Codec MP3
- Channels 2
- Bitrate 195 kbps
- Album Gain -8.44
- Album Peak 1.000000
- Album Range 13.375744
- Audio Channel Layout stereo
- Gain -8.44
- Loudness -20.31
- Lra 0.00
- Peak 0.409332
- Sampling Rate 44100 Hz
- Display Title MP3 (Stereo)
- Extended Display Title MP3 (Stereo)
XML:
musicAnalysisVersion=“1”
Not working
- Codec MP3
- Channels 2
- Bitrate 128 kbps
XML:
Interestingly some still had
but a few (I only found like 1 or 2) were missing musicAnalysisVersion all together
Any ideas on what happened and maybe a possible fix? Trying to Plex Dance if possible because another Sonic Analysis would take a while plus I’m worried I’ll lose my ratings/play data
