Lyrics not found
Yeah I just noticed this teh otther day. Didnt change anything on my PMS for my WD MyCloudEX2 Ultra so not sure what caused the lyrics option to dissapear when playing on Plexamp. Everything was working perfectly and then all of a sudden the lyrics were gone. I thought it was just a few songs or albums / artists but I lept checking a LOT of my library tracks and NADA. Lyrics optionn is GONE.
What happened? My wife is going to be really mad about this as she is all about lyrics.
Yes Im a Paid PlexPass member.
thanks
Do you see the Lyrics when using Plex Web?
Yup just tested it out now on the Web version of Plex (windows)
Works fine and its the scrolling lyrics not just the static ones
see screen cap below
Not sure what’s going on then. I see the option to “Show Lyrics”. Can you doublecheck what version of the app you are running?
For my Windows laptop Im running Plex web 4.49.2
For my Android mobile app on PlexAmp Im using version 3.4.0
I’m also using 3.4.0 and I see the option so not sure what’s going on.
