Mac client is not updating anymore
Server Version#: Version 1.41.0.8992
Player Version#: Version 1.100.1.221-94aa83fb
For a while now automatic updates are not working for me on two different Macs.
Plex Player has stopped updating a while ago, but Plexamp was ok until it also stopped updating a couple of weeks ago.
Is anyone else experiencing this?
I have found if a VPN is active it will not Auto update
The last two upddates have not auto updated, no VPN active. Been doing it manually.
By manual, are downloading from Plex.tv or are using update indicator in the browser tool bar
I go here and download the latest manually and replace the current version. I have not seen a prompt in the app to update, but haven’t paid too close of attention.
https://www.plex.tv/media-server-downloads/?cat=plex+desktop&plat=macos
They just posted an update, I closed and relaunched the plex app. It didn’t try and update, also there isn’t an option on the dashboard.
I also checked pihole to make sure there was no dns address blocked and it’s not blocking any traffic.
Tried a lot of things for the past couple of months, including things mentioned here.
Updates are just not working.
Also, it would be nice to have an option to force update manually…
@vaxter Can you please check out your plex.ini file located in ~/Library/Application Support/Plex. We do have a param to disable the auto update feature that requires modifying this file. Here is the process to disable auto updating the Plex for Desktop/HTPC:
  • Find the [debug] section - add one if one does not exist
  • Add disableUpdater=true directly under the [debug] header
  • Save your changes
So if disableUpdater=true is there, close the app, remove disableUpdater=true, save, and restart the app.
Another directory to check is ~/Library/Caches/Plex/updates. This is where previous versions are stored and where the new version is downloaded to to eventually kick off the auto updating task. You should be able to monitor this directory after starting up the app to see any new version be downloaded. Usually takes a couple minutes after launching the app to grab the release. Once the release is there, close the app, and restarting it should kick off the update.
I just checked my plex.ini at ~/Library/Application Support/Plexand it doesn’t contain any instance of disableUpdater=true
I opened the file in bbedit and did a find on disableUpdater=true and disable and went through all the instance and found none.
Checking ~/Library/Caches/Plex/updates and found the past versions, 1.100 is where it stopped auto-updating and @Swifter8520 posted that other thread. Can zip and send the plex.ini if it helps.
There is definitely an issue here. Thanks for raising @vaxter and everyone else with the extra details. We have an internal issue tracking this problem.
@vaxter and anyone else, this issue should be resolved. There was a backend bug that wasn’t populating the necessary data that the updater needed in order to fetch the latest update.
@Atomatth the new version Plex for Mac, Windows, and Linux - #131 by rubenamorim is not updating fyi.
What version are you currently on?
Sorry, Version 1.103.1.238-223cbba6 is not auto updating to 1.104.
edit: maybe I jumped the gun, I just closed and relaunched again and it updated to Version 1.104.0.241-2164c90a
