hello.
i have same issue
i tested ios/android/web client
how can we solved?
Hello. Are there any solutions without downgrading server for this?
I also have the same problemā¦
The bug has been found. The fix is now in the release pipeline and should find its way into one of the next server releases.
Until then, possible workarounds are:
- downgrade to plex server 1.16 , set the language prefs again, then upgrade again.
- edit the plex database directly as shown in here: How-to Guide: Setting default language for audio track & subtitles on managed accounts (e.g. Guest)
Thanks. I finally fixed my issue with the database update.
Hi OttoKerner,
Have you an estimated date to fix this issue, please? I canāt use Managed Users at home because of this, Plex pass users could deserve a good solution, do you think?
Thanks for your time.
Sorry, I canāt tell you more precisely than above.
To be honest, using DB Browser (SQLite), it is really simple if you have some āprogrammingā knowledge. It take about 3min to fix this.
You said it, dear, Iām not a programmer. Could you give me some tricks to do it, please? Iāll try, I really need to change it.
Thank you so much.
