Manifest file with metadata per media
Some Videos just fail to be scraped properly by Agents or there is no proper online source where to scrape from.
Is there a possibility to add something like a “manifest” (XML) file next to the actual media, which contains what shall be in the library fields for the particular media? This could even be done as an Agent itself.
Good to know if there is something like that already!
I believe it’s only possible to use .nfo files for music where you’d add the lyrics.
No, lyrics are only read from plain .txt and .lrc (timed) files.
.nfo files are not supported at all.
If the library is still using legacy agents, you can install the 3rd-party .nfo importer agents
However, I don’t know if these are still working.
Apart from that, if you have “unmatchable” videos, you want to use the mp4/m4v file container and embed your metadata into these.
Thanks for the clarification
