Server Version#: 1.16.4.1469
Player Version#: 2.39.0.1005-1b0839a8 (Windows 10)
Is there seriously no way to manually offset audio in PMP?
Im using TV mode and tried the following tricks that I found by google…
- Audio Sync mode - changing it from the default (Audio) makes the delay much much worse
- Native OpenGL - made no difference but the colors went crazy. Super vivid and definitely not what its supposed to be.
- Disable Direct Stream - Made no difference
- Tried switching to Web mode - Audio problem still exists and now HDR isnt working. Colours all look really washed out
I used to be able to do this in Plex Home Theatre - why is it no longer an option?
BTW, audio sync works perfectly using VLC, MPC-HC etc - only in plex that it goes wonky
You can use
- Alt+A – Increase audio delay
- Alt+⇧ Shift+A – Decrease audio delay
in TV mode.
There is also the plexmediaplayer.conf which can take constant delay parameters, one for each picture refresh rate.
https://support.plex.tv/articles/207338798-advanced-configuration/
(If you don’t need a different delay for each movie, but a general one)
Fantastic! Will give it a go later when I’m back home.
Where can I find a concise list of keyboard commands for PMP (TV mode)?
You can use this
https://support.plex.tv/articles/208052807-controlling-the-app/
Or you simply take a look at the keyboard.json file in
C:\Users\USERNAME\AppData\Local\PlexMediaPlayer\inputmaps\examples
https://support.plex.tv/articles/216459997-create-your-own-inputmap/
system
Closed
5
