Manually entering tuner ip is only checking for hdhomerun devices not vbox
I’m trying to access my vbox tuner which is in a different subnet than my plex server, when they are in the same subnet everything works fine.
From the logs i found that plex is doing a post-request to >ip<:55555/devices/discover to discover the available tuners of my vbox.
When I manually enter the ip in plex it is doing a get-request to >manual ip</discover.json.
From my server i am able to curl the correct request and get a result that makes sense. So I’m assuming that the “enter ip manually” function is only looking for hdhomeruns tuners not vbox tuners and therefore I’m unable to connect mine.
Let me know if any other information is needed and/or im misinterpreting anything
Expected behavior:
manually entering ip adress of a tuner should look for hdhomerun and vbox devices
actual behaviour:
only looks for hdhomerun devices
Server Version#: 1.20.4.3517
Player Version#: unrelated
Tuner Make/Model: vbox XTi-3452 Cable
Bump
