Server Version 1.17.0.1841 (I had to roll back from 1.18 a few days ago because 1.18 update was causing big problems).
When I added a few more movies lately I noticed that Plex was not showing the locally-stored extras (particularly, trailers) associated with some of those newly-added movies. I checked a few of the pre-existing movies and saw that they were still displaying the extras as before. However, since then I’ve done more checking and it seems about half of the ones I’ve checked still show the extras, and half no longer do.
All of these extras files are contained in subfolders with the proper names (e.g., “Trailers”, “Featurettes”, “Scenes”, “Interviews” etc.) per the instructions I’ve found, and I can’t detect any difference in the file/folder naming structure for the ones that still work and the ones that don’t.
I’ve tried doing the “Plex Dance” for a couple of the movies having the problem, but it had no effect. I’ve also tried changing various agent settings for my movie library, and refreshing all the metadata after each change, and emptying the trash, and cleaning the bundles, but nothing seems to have worked. And now there’s probably a good chance that I’ve changed something wrong and forgotten how to change it back.
Does anyone have any idea why some would work and some (with exactly the same naming structure) wouldn’t work? And can anybody explain exactly how the agent settings should be set to make this work consistently?
