Map issues Plex
Hi I have installed Plex on my Qnap my problem is that I can’t get more than 22 CDs in my music folder when I put the 23rd CD Plex creates a new folder.
Does anyone know how I can change this?
Plex Versie 4.76.1
Please show us what you mean.
4.76.1 is the player version. Server version is shown under Settings - Server - General
I have 22 cd’s in folder music when i make one it comes in another folder that plex creates itself
Server Version 1.27.2.5929
mus 1
22 cd’s
1 cd
Plex does not automatically create libraries. Plex is able to handle 1000s of albums in 1 library. Something else is going on. Can you:
  • delete that second music library from Plex
  • “scan library files” for that first library
  • grab the entire server log zip file and upload it here
It worked
I added CDs via add library this didn’t work but via scan library files it works fine.
Thanks for your help
Best regards Zeger
