Mapping channels
I have a HDHomerun Prime and it is working great but when I went to set up my live/DVR TV in plex not all the channels are showing up on the right side to be able to map to. The scan has them all on the left but I do not have the correct names to match to on the right because they are not all there. I had it set up with another HDHomerun tuner, not a prime, and that is the list of channels I have on the right to map to. Since that is from over the air there are no cable channels to map to.
How do I update the list to select from?
Pled DVR works with tuners that are of the same type, either all OTA or all Cable not mixed. The DVR ties to the EPG selected when the first tuner is added.
I’m experiencing a related issue. I’m unable to map channels past 999. The dropdown that lists all the channel stops at 999.
I have switched to the Cable tuner how do I get it to list the EPG for the Cable one. Is there a file that can be changed?
I’m not using the OTA tuner any more so I need the list for the Cable card to show.
Delete the DVR completely, then when recreating you will be prompted again for the EPG source. Your currently scheduled recordings should be fine unless you have any set to a specific channel which will then need to be changed based on the new channel list in the DVR.
Thanks for your time. Worked like a champ.
My setup has channels from several countries and several providers. Is it possible to add a 2nd or more epg source link? I know that this is not an option in the tuner setup. However, can I do this somewhere within Plex’s directories by editing a file?
