Marantz8006 and Airplay/DLNA
Server Version#: 1.30.0
Player Version#:9.20.0.806
Ik have a QNAP NAS with Plex server installed.
On PLEX>Settings>DLNA, i have Enabled the DLNA server.
Remote Acces also Enabled.
Also de cliënt Plex App on Phone installed!
I can see my music.
I have an Marantz ND8006 steeamer so to say, it supports DLNA and Airplay
But Plex doesnt see this Marantz!
Other Apps have no problem detecting it!
Does someone knows what the problem could be?
Many thanks in advance.
Ronnie vd Wiele
The Plex for Android app is not a DLNA client. It cannot see DLNA devices lie your Marantz. You need to use another DLNA client for Android to stream to your Marantz. If your Marantz supports Chromecast, you can use the Plex app with that, but if you’re not seeing it, then it likely does not support Chromecast. Our Plex for iOS also is not a DLNA client, but it can Airplay so it can work that way.
Ok, thanx!
That could be the problem!
Shall try that!
