Whenever I want to Match or Fix Match and I select Plex Movie (it defaults to the legacy agent, another annoyance) it changes the language from English to Bahasa Indonesia. Pain in the rear. Can this be fixed please?
Did you actually upgrade your library to use the new agent or did you just change the drop down in the library settings?
If you only changed the library dropdown that would only affect new items and old items will be default to the legacy agent they were originally matched with.
the agents have different language choices and the new agent should not be mixed in a library with others. If you didn’t do the “upgrade matching” then change the library back to Plex Movie Legacy and then the option should appear in library menu.
Edit the item and change “metadata language” to library default to fix that one item.
That fixed it. Weird that I would have to do that for each library, but it did work.
A big help for me too. Thank you @BigWheel !
