Matching problem on Plex server on Qnap
Lately I have issues on my plex server. Normally when I add new movie or any media files, when I press match, it automatically matches the media file and collect all the data. However last a couple days the plex server hasn’t applied matching until I restart the plex media server.
I did not change any thing on my plex server and it started suddenly. Do you now how I can fix it?
we need more info.
  1. Which PMS version is installed? 1.3x.x or 1.40.x beta ?
  2. Can you provide us server logs ZIP file which capture some of this not working?
    (Scan files, let it finish, then gather the DEBUG server logs – helps most)
1.32.8.7639, Synology DSM 7.
I had a similar issue today, I added several movies and TV shows and noticed none of them had matched at all.
When I tried to manually match a few of the movies, there were no results (the “Match” dialog showed “Nothing found” instead of a list of potential matches).
Same if I went to an already-matched movie I had added in the past and tried Fix Match: nothing found.
After seeing this topic, I manually stopped and restarted PMS, manually launched a library scan, and it matched all the movies and shows I had added earlier successfully.
The Fix Match dialog also now returns results instead of “nothing found”.
Plex Media Server Logs_2023-12-28_01-31-09.zip (3.5 MB)
This is the only workaround, until you update to at least version Plex Media Server - #609 by drzoidberg33
Thanks! Good to know. But why?
PMS release notes:
  • (Agents) It is possible that agents are not initialised during startup on rare occasions (#14654)
Ah, so if the agents were started properly (like e.g. they seemingly were when I restarted PMS two days ago), then they presumably would keep working so long as PMS doesn’t get stopped?
Without context, I somehow thought you were saying one would have to restart PMS every time after adding new content to a library…
Cheers :slight_smile:
