Server Version#: 1.24.1.4931
Cannot match many Russian TV shows.
Fix match -
Tvdb-
Looks like this example cannot pass to meta.plex.tv
Maybe plex agent seek more information then added to tvdb source and this is error ?
Looking at your folder structure I think you have an error. Change …
[TVDB-395828]
to
{tvdb-395828}
in your folder and see if that helps when you try and match/fix match.
@drzoidberg33 so problem same or … ?
How are your files named?
use lower-case letters {tvdb-395828}
I ran a quick test and could not get this show to match either. In addition I could not find the show on IMDB or TMDB. I’m open to correction on this but I think the new plex agent requires movies/shows to have a IMDB entry as a starting point which is then linked to TMDB and TVDB as the new agent consolidates its metadata. So without a IMDB record to start with plex cannot match the show.
However @drzoidberg33 should be able to confirm.
It doen’t need for fix match by tvdb-id…
Yes, maybe you right. But priveous agent doesnt require imdb record.
So I need a answer, is it a bug\parser error or some show without imdb will be plex agent ignored
I don’t think IMDb is a requirement, because Plex doesn’t seem to take any data from IMDb.
I do think I remember a Plex person mentioning that inconsistency between TVDB and TMDB can be an issue, but I can’t find the thread.
Plex match well after adding tmdb record
So both tvdb and tmdb records required for plex agent ?
There is one here:
Which suggests the Show must exist on the TMDB
