Material acceleration artifact - Android TV
Hello everyone,
I have a H265 - HDR video that has artifacts as soon as hardware acceleration is disabled.
On PC, for VLC, MPC, Plex for Windows (Use Hardware Decoding), I can disable it and everything works fine.
However, on Plex - Android TV (Sony A95L - 2023 TV), I can’t find any setting to deactivate it, and as a result, I get a lot of artifacts.
Would you have a solution to disable it and no longer have artifacts ?
Thanks a lot
