Maximum movie in a folder?
i have a folder having more than 500 movie file
do i need to split my movie into multiple folder
is there a maximum file number into a folder for plex
is there any advantage to split movie into multiple folder ?
and is there a limit (number of movie)to have in the same library for plex
in total i have more than 2000 movie file
or just put all movie in same folder ?
thanks
my pc
intel core i5-4690k cpu @ 3.50 mhz
ram 16 GB
Personally, I’d avoid folders with more than a few hundred files.
You can drastically speed up library scans by giving each movie its own subfolder. Because then Plex will only scan folders with changed content since last scan.
There’s software to automate this, btw.
what software ?
e.g. Filebot
