Meda logs
Hi, ive searched but cant find anything… i recently had an 8tb drive with media on it, is there anyway to search logs to figure out what was on that drive, without manually having to go through every thing in my library and see whats missing?
thanks, john
If you haven’t emptied the Plex trash, you should still see all those lost items in your Plex library. If you do, go directly to step 3)
If you don’t see them anymore,
  1. disable “Empty trash automatically after every scan”
  2. https://support.plex.tv/articles/202485658-restore-a-database-backed-up-via-scheduled-tasks/
  3. Then use the Export feature of
    WebTools NG
