For a couple of weeks ago I’ve bought a Nvidia Shield TV which primarily is used as a Plex server. Even though there’s a connection to the server, Plex keeps saying my media is “Unavailable”. This is a problem on both my Nvidia, but also on all of my clients. My media is stored on my NAS which, of course, is connected to the Nvidia. The only way I can help the “Unavailable” problem is by dismounting the NAS from the Nvidia in Nvidia’s settings and remount it afterwards. After this procedure is done I can play all of my media, but after a couple of hours they get unavailable again.
The Nvidia and my clients all have the latest software update.
It sounds like when the Shield goes to sleep it loses mounted NAS shares. I’m pretty sure I’ve seen this happen before. I’ve never heard of a solution for it though.
I’ve heard about it too, but it doesn’t seem to be the case for me. In the settings I’ve manually denied my Nvidia to go into sleep mode. I’ve even activated the developer options, in order to activate the “Stay awake” option.
Try rebooting the Shield and then mounting the NAS shares again, then when the shares become unavailable download the server logs and post them here (enable debug logging but not verbose logging, and make sure you do not have the plex token turned on for logging). Hopefully the logs will provide some insight on what is happening.
I have the same exact thing happening to me. Thought it was an issue with my NAS going to sleep or rebooting itself, but that’s not the case. Disabled sleep on the Shield TV and that has not fixed the issue. Super annoying because there is no way to fix it remotely. No way to remote into the Shield TV.
@aladegaard92 said:
By “debug logging” do you mean “USB debugging”?
By “Verbose logging” do you mean “Enable Wi-Fi Verbose Logging”?
By “Plex token” what do you mean?
I just started having this problem this weekend, I have a (2015) shield for months without this problem, then this weekend it started. Strange thing is I updated the Nvidia Games app on Friday with the new version, then this started happening.
I’ve got the shield 2015 version as well and have been experiencing this issue for a couple of weeks now. I’ve tried rebooting the shield as that sometimes seemed to help. I’ve also rebooted my NAS and last week even deinstalled plex from my shield to remedy the problem. That worked, fort a bit. Right now the problem is back and I’m running out of options. It worked perfectly for a long time but plex nog working is seriously making me think about switching to Kodi. I’ll try the remounting of the NAS and increasing the timings on the disks but after that I’m done. I’ve been using Plex for years with a lot of satisfaction but a non working product, even one I’ve paid for, is of no use to me.
@thruster999 said:
I’ve returned my Shield because of this issue. Routinely dismounting and mounting my external content is a major pain in the A$$.
When Shield Plex is ready for market I’ll be back - unless something similar/better comes along.
Aside from the occasional issue that crops up from an app update (or a full on update to the new 2017 Nougat build) the Shield has been ready for some time now. I feel like you overreacted a bit by returning it unless you feel that there is a comparable product out there, which I don’t believe there is.
Whenever there is an issue with the Plex App I simply just use the Plex Add-On for Kodi.
Except this problem is a problem with the Shield mounting SMB shares. Not a problem with how the Plex app operates. The Plex plugin for Kodi shows the same “unavailable” status for all media.
