I have persistent media playback failed when playing movies/tv shows. I am on Version 1.10.0.4516 on my PC and watch it on my xbox one thats wired to the same router as the PC. Im sure I will have to provide logs as explaining it wont do much im just not sure when to acquire the logs. during a playback failure, or just grab one now?
for starters you could attempt narrowing this down. do you get the same error when playing videos on a different client (plex web)? that should help identify what log you should go for (client vs. server side).
In that case youâre probably best off by looking at the clientâs log (should be accessible/mentioned in settings. Doesnât need to be immediately after an error as long as you remember when the last error occurred (where in the look to look for)
I went to settings/web/debug and that didnât look like what ive seem here. so then i checked settings/server/help and chose to download logs, which looks more like what I have seen here. Is this correct?
Correct, thatâs the server log. However I consider the information youâre looking for are on the Xbox. Is there a similar entry in the Xbox Plex clientâs Settings? (Sorry⊠Iâve got no Xbox at hand to provide more guidance for that part⊠on the Android TV client thereâs an option to temporarily enable access to the log in your home network, also displaying the exact path/URL).
there is, i think. Its called âLog to media serverâ under the privacy settings. I enabled it as it said it will allow the xbox to send logs to the media server.
