Media added which have multiple qualities eg, 2160p and 1080p, the info part will show the quality of the first version added to the library, which makes sorting by resolution pointless. I think it should automatically show the highest resolution available.
Currently when you sort by resolution some logic unknown by me is used to determine which resolution to use for titles with multiple files where each file is of a different resolution.
For example, if I have two copies of Movie A in my library, A.1 @ 1080p and A.2 @ 4K Plex combines these into one Title. When I go to the Library and Sort By Resolution 1080p is currently used. However, I’d like to see all 4K titles in my library and this sort would provide that if 4K was used.
I assume the logic is currently either use the first resolution added for the Title or use the lowest resolution. If there is a desire to maintain this logic a user setting could be added to change the behavior to select the highest resolution.
Thank you,
Tom
