Merged Movies show as bit rate not name
Server Version#:1.32.4.7195
Hi
This is probably me being really stupid but I’m hoping you can all help me out
I have 2 versions of a movie
Nightbreed {release}
Nightbreed {directors cut}
I’ve named them as above and they are merged but when I click the … and select version I don’t get names I get bit rate and resolution and then need to guess. I have other films I want to merge the versions of so could really do with knowing what I’m doing wrong.
I’m guessing I may need to edit the file properties I’ve split the files apart and manually given them versions then merged them but end up in the same position.
All help really gratefully received
J
PS if I’ve put this in the wrong place please let me know where to move it to!
Editions are used differently.:
https://support.plex.tv/articles/multiple-editions/
Hi OttoKerner
I’ve changed the names to
Nightbreed {edition-Director’s Cut}
Nightbreed
But still can’t see the names when I click on the … then play version just the bit rate and resolution.
Am I still missing something?
Hopefully I’ve attached some screenshots to help
Ja
plex1
plex2
plex3
Editions don’t use the ‘Play Version’ menu, they show up as separate entries in your library. You’ll have to split them apart and then ensure the Edition field is set correctly:
I recommend to Plex dance the renamed files.
Thanks both I’ve now got them working with the proper versions just need to stop them merging when I scan and I’m all done.
Thanks again for all the help
