Metadata for one show is not working
Server Version 1.16.0.1226
For some reason the metadata for: Euphoria US does not work. I tried the following things:
  • Delete and put it back
  • Rename: naming is according to the norm i thought:
*Euphoria (US) - S01E01 - Pilot WEBDL-720p.*mkv
I checked the agents and the order:
  1. TheDVB
  2. TheMovieDatabase
  3. Fanart.tv
456, other including Local Media Assets.
I cannot fix the match because there is no initial match. For all other media on the server it works perfectly.
Does someone know what is going on?
thx.
You should still have an option to match it. (You need to select the ellipsis at the top (Show) level
My folder structure:
Euphoria (US)
– Season 01
---- Euphoria (US) - s01e01 - Pilot.mkv
Comes up as unmatched, but still have an option to match it
If you remove Us from the title box, and then search, it comes up (for me) as the second item in the list: Euphoria 2019
That worked, needed to Match on show level not on episode level,
Thx a lot!
Mine is
Euphoria (US) (2019)
– Season 01
---- Euphoria (US) (2019) - s01e01 - Pilot.mkv
Comes up fully matched.
As test. I did fresh
  1. No year needed
  2. Kept the US name because this is how listed on TVDB
http://platypus.thetvdb.com/series/euphoria-us
[chuck@lizum ~/Downloads.168]$ cd /vie/tv3/Euphoria\ \(US\)/
[chuck@lizum Euphoria (US).169]$ ls -la *01
total 88
drwxrwxrwx 2 chuck chuck 4096 Jun 20 03:39 ./
drwxrwxrwx 9 chuck chuck 4096 Jun 20 03:41 ../
-rw-rw-rw- 1 chuck chuck  157 Jun 20 03:39 Euphoria (US) - S01E01.mkv
-rw-rw-rw- 1 chuck chuck  157 Jun 20 03:39 Euphoria (US) - S01E02.mkv
-rw-rw-rw- 1 chuck chuck  157 Jun 20 03:39 Euphoria (US) - S01E03.mkv
-rw-rw-rw- 1 chuck chuck  157 Jun 20 03:39 Euphoria (US) - S01E04.mkv
-rw-rw-rw- 1 chuck chuck  157 Jun 20 03:39 Euphoria (US) - S01E05.mkv
-rw-rw-rw- 1 chuck chuck  157 Jun 20 03:39 Euphoria (US) - S01E06.mkv
-rw-rw-rw- 1 chuck chuck  157 Jun 20 03:39 Euphoria (US) - S01E07.mkv
-rw-rw-rw- 1 chuck chuck  157 Jun 20 03:39 Euphoria (US) - S01E08.mkv
-rw-rw-rw- 1 chuck chuck  157 Jun 20 03:39 Euphoria (US) - S01E09.mkv
-rw-rw-rw- 1 chuck chuck  157 Jun 20 03:39 Euphoria (US) - S01E10.mkv
-rw-rw-rw- 1 chuck chuck  157 Jun 20 03:39 Euphoria (US) - S01E11.mkv
-rw-rw-rw- 1 chuck chuck  157 Jun 20 03:39 Euphoria (US) - S01E12.mkv
-rw-rw-rw- 1 chuck chuck  157 Jun 20 03:39 Euphoria (US) - S01E13.mkv
-rw-rw-rw- 1 chuck chuck  157 Jun 20 03:39 Euphoria (US) - S01E14.mkv
-rw-rw-rw- 1 chuck chuck  157 Jun 20 03:39 Euphoria (US) - S01E15.mkv
-rw-rw-rw- 1 chuck chuck  157 Jun 20 03:39 Euphoria (US) - S01E16.mkv
-rw-rw-rw- 1 chuck chuck  157 Jun 20 03:39 Euphoria (US) - S01E17.mkv
-rw-rw-rw- 1 chuck chuck  157 Jun 20 03:39 Euphoria (US) - S01E18.mkv
-rw-rw-rw- 1 chuck chuck  157 Jun 20 03:39 Euphoria (US) - S01E19.mkv
-rw-rw-rw- 1 chuck chuck  157 Jun 20 03:39 Euphoria (US) - S01E20.mkv
[chuck@lizum Euphoria (US).170]$
metatata
It does all match fine (now) with the same naming scheme that I used.
(just scanned my TV Library on a different server)
I guess the record on the tvdb got updated or the caching caught up, as it was not matching yesterday without manual intervention.
