Metadata is not being fetch from episode 124 and above
Server Version#: 1.19.5.3112
Player Version#: 4.40.1
When I refresh the metadata for an episode, it does not grab the correct episode number, and thus it’s not matching.
All episodes are named the same way: Name - sXXeYYY
The problem is that everthing is fine until episode 123, all others after that have the same issue as 124.
Please check line 44 in both logs.
For the file: /animes/Black Clover/Black Clover - s01e123.mkv in file 123.log
2020-08-21 17:19:37,103 (7f4af67fc700) :  DEBUG (model:32) - Loading model with GUID com.plexapp.agents.thetvdb://331753/1/123?lang=en
For the file: /animes/Black Clover/Black Clover - s01e124.mkv in file 124.log
2020-08-21 17:21:06,500 (7fe4ad7fa700) :  DEBUG (model:32) - Loading model with GUID com.plexapp.agents.thetvdb://331753/1/24?lang=en
Why is it getting 1/123 and 1/24 if both are named exacly the same way?
123.log (30.9 KB) 124.log (30.9 KB)
Are your lower-numbered shows named E001, E002, E099? Or are they E1, E2, or E01, E02?
I see this comment from Otto that it matters:
999 Max episodes and Doubled Episodes - Please Help - #4 by OttoKerner
They were all 2-digit, e01, e02 … e99 e101 …
I them tried with 1-digit only, just for the lols, and refreshing the episode didn’t work
Switching to 3-digit and refreshing the entire series did work after all, but I still think it’s weird that it was fine for 123 but not for 124.
Either way, Thank you.
I agree, it’s odd that it didn’t break going from 99 to 100. And it’s odd that E12 would influence E124.
:man_shrugging:
Glad it helped.
