Metadata wrong/missing on daily episodes
Server Version#:1.18.1.2019
Daily episodes like The Late Show with Stephen Colbert or the Daily Show with Trevor Noah are not displaying Metadata on new episodes anymore. Other Shows seem fine.
Examples of the File names, inclusive of directory structure, exactly as you have them please ?
Directory: series/The Late Show with Stephen Colbert/Season.05
File names are like this:
‘The Late Show with Stephen Colbert - 2019-11-07 - Dr. Phil McGraw, Chris Parnell, Cold War Kids.mkv’
‘The Late Show with Stephen Colbert - 2019-11-12 - Liev Schreiber, Daniel Kaluuya, Cold War Kids.mkv’
‘The Late Show with Stephen Colbert - 2019-11-13 - Tim Robbins, Nicolle Wallace.mkv’
Those have not changed for 2 years and worked fine so far. It started with today’s shows.
Edit: Other shows are impacted as well, like AHS and Short Treks from today. Seems to be a general issue
I will need the DEBUG logs please.
It doesn’t make sense to me so hopefully the logs will show what’s happening.
I suspect TVDB side of the data.
Silly question:
Season.05
or
Season 05
Season.05, does not matter though.
Here is the part form the debug logs when i refresh the offending item from the daily show for example:
Nov 14, 2019 17:31:54.085 [0x7f68d27fc700] DEBUG - Notification of new metadata for com.plexapp.agents.thetvdb://71256/25/2019-11-13?lang=en [id=47927] (success=1) for 1 items.
Nov 14, 2019 17:31:54.086 [0x7f68d27fc700] WARN - Unable to load episode file ["seasons/25/episodes/2019-11-13.xml"]
Nov 14, 2019 17:31:54.087 [0x7f68d27fc700] DEBUG - Item 47927 (2019-11-13) Scanning metadata graphic elements in XML file "seasons/25/episodes"/2019-11-13.xml
Nov 14, 2019 17:31:54.087 [0x7f68d27fc700] ERROR - Error parsing XML: Empty or non-existant file..
Nov 14, 2019 17:31:54.088 [0x7f68d27fc700] DEBUG - Loading information from media bundle for part ID 182236 from "/var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Media/localhost/8/303696555a119639faf9bc1d95b2f310bbb9f1e.bundle/Contents"
Nov 14, 2019 17:31:54.089 [0x7f68d27fc700] DEBUG - Loaded metadata for 2019-11-13 (ID 47927) in 10.000000 ms
Nov 14, 2019 17:31:54.089 [0x7f68d27fc700] DEBUG - Done with metadata update for 47927
I’m seeing the same thing as well:
Nov 14, 2019 16:36:13.443 [0x7fdbb6ffd700] DEBUG - Request: [127.0.0.1:39872 (Loopback)] GET /:/metadata/notify?guid=com.plexapp.agents.thetvdb%3A%2F%2F289574%2F5%2F2019-11-13%3Flang%3Den&path=TV+Shows%2Fa%2Fb320edf2dcd69cfa210ff6c70e5d3ecf100547e.bundle&force=1&queueSize=0&id=60543&success=1&async=1 (33 live) GZIP Signed-in Token (manbeard)
Nov 14, 2019 16:36:13.443 [0x7fdbb6ffd700] DEBUG - Queueing up com.plexapp.agents.thetvdb://289574/5/2019-11-13?lang=en for loading, there are 0 items in the queue.
Nov 14, 2019 16:36:13.443 [0x7fdc424b4700] DEBUG - Completed: [127.0.0.1:39872] 200 GET /:/metadata/notify?guid=com.plexapp.agents.thetvdb%3A%2F%2F289574%2F5%2F2019-11-13%3Flang%3Den&path=TV+Shows%2Fa%2Fb320edf2dcd69cfa210ff6c70e5d3ecf100547e.bundle&force=1&queueSize=0&id=60543&success=1&async=1 (33 live) GZIP 0ms 166 bytes
Nov 14, 2019 16:36:13.444 [0x7fdbdcff9700] DEBUG - Notification of new metadata for com.plexapp.agents.thetvdb://289574/5/2019-11-13?lang=en [id=60543] (success=1) for 1 items.
Nov 14, 2019 16:36:13.445 [0x7fdbdcff9700] WARN - Unable to load episode file ["seasons/5/episodes/2019-11-13.xml"]
Nov 14, 2019 16:36:13.446 [0x7fdbdcff9700] DEBUG - Item 60543 (2019-11-13) Scanning metadata graphic elements in XML file "seasons/5/episodes"/2019-11-13.xml
Nov 14, 2019 16:36:13.447 [0x7fdbdcff9700] DEBUG - Loading information from media bundle for part ID 70298 from "/var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Media/localhost/7/a6f970c7d36e87fe43be783555c8bb2cb0d0c89.bundle/Contents"
Nov 14, 2019 16:36:13.447 [0x7fdbdcff9700] DEBUG - Loaded metadata for 2019-11-13 (ID 60543) in 0.000000 ms
Nov 14, 2019 16:36:13.447 [0x7fdbdcff9700] DEBUG - Done with metadata update for 60543
Which PMS version please?
1.18.1.2019-c186313fe
While i’m looking through things here, please do the following:
  1. Scan files
  2. Empty Trash
  3. Clean Bundles (most important step)
  4. Refresh the metadata for that show.
To help me, do you have the previous 1.18.0 and can you test it?
Helps check to see if a simple/stupid regression.
No effect and no I don’t have it.
I’m in staff meeting now and backposting here:
  1. TVDB is having problems. Operations is working with them on that.
  2. Plex.tv was also yo-yo’ing for 2 days. This mostly impacted remote access but
Thanks ChuckPA.
I don’t think this is a Plex issue. I use FileBot to rename files via theTVdb before saving them to a Plex accessible directory. FileBot has been unable to find matches for S05E41 and S05E42 of the Late Show with Stephen Colbert. I feared something nefarious given Colbert’s frequent criticism of you know who.
I have investigated further, confirmation not yet in hand, but known good media on known good PMS versions lose poster art.
i suspect TVDB deploying their API v3 again with equally limited success as their last attempt.
It appears to be the “100 episode limit” issue.
I will relay as soon as I have more to go on.
