Metadata issue for The Daily Show
Server Version#: 1.21.2.3943
I recently consolidated my setup down from having my media on a external nas to now it is local to the Plex Server, I encountered some permissions issues when I did that and it required me to fix those and then I had to fix a whole bunch of shows/movies that where no longer matched properly.
Everything seems to be ok with the one big exception of The Daily Show, it seems to match the correct TVDB Entry but how is presenting is not correct.
For the Season’s it is showing “Season 2020” and “Season 2021” and it does not seem to be updating summaries properly. I am struggling to figure out how to fix it.
So I have tried numerous times to do The Plex Dance with different styles to the naming convention.
It just refuses to seem to pull the metadata. Right now when you view the show info that is not even populated properly even though it seems to pointing to the right tvdb entry.
