Server Version#: 1.14.1.5487
Player Version#: 3.79.0
Had to rebuild due a drive failure. I restored the Plex database, but now posters and background images are mostly gone. I assume it’s an agent thing, but I can’t figure out how to get the artwork back.
Please define “database restore”.
Did you just create your library anew
or did you save and restore the old Plex database file
or the whole Plex data folder
Either way, when you configured the server, did you move the Plex data folder to a different location, away from its default? And if you did, was it onto a volume that is
I’m fine doing a global refresh. When I refresh the metadata of my Movies (350 movies), the refresh takes less than 30 seconds and nothing changes. I’m thinking my agents are messed up, but not sure how they should look.
