Metadata not retrieved since end of June
Server Version#: 1.32.4.7195
Player Version#: Web 4.109.2
Four days ago I download the film Purple Hearts (2022) named like that in the movie folder and the agent was able to retreive metadata but today, I try to add Cinderella Man (2005) and In the Heart of the Sea (2015) and no data from the both film are retrevied… I firstly tried to renamed in french title as for other film in my library wiythout result (the 3 files are in the same folder). Also the english naming didn’t help… I didn’t found any mention of the association in the log… seems that the agent are unable to connect but I didn’t change anything on my side
I’m having the exact same issue…with both tv shows and movies…using plex media server 1.32.5.7210-77f799fa on windows 10 machine…go to fix match, no matches found using plex series agent…no auto matches either…
Refresh metadata just remains grey after pushed, and no results still…tried it on items from a few days ago which are fine, but when hitting “match” is comes up again as no matches found…
All files are 100% formatted to the proper convention, as it i’m trying it on those that are properly showing up…
I just checked and the music agent using last.fm is not working too…
I’ve had the the same issue for the past few days for movies and TV Shows. When manual matching the search never returns anything for either.
I tried changing my TV library to use the TheTVDB which seemed to work but of course Plex wants to update it to use the Plex TV series.
Thanks for the tip, i did it with the tv shows too…and it seems to be working as well…will try it now with movies using the movie database as the agent…
Seems to work!
Same for me, I need to use the last.fm / TVDB / MovieDB in order to retrieve the data and then Plex server required me to switch back to Plex agent (officiel recent and better) … who didn’t provide any info and didn’t retrieve any data… becoming verey boring :exploding_head:
yes it works temporaly… but nobody seems taking care of this issue on plex agent
What was the tip?
Can you provide the server logs after adding something and not getting metadata
Changing the db agent…
