Metadata on TV Shows Not Working Please Help
Can someone help me I am a very novice user to plex,
I have just reshuffled my files around, deleted all of my data and I’m rebuilding it,
plex won’t download for my tv shows, I have no idea why?
Plex Media Scanner.log (51.4 KB)
please help?? the files are labeled correctly as seen in the log
No, they are not:
N:\Tv Shows\Baywatch\Series 10\Baywatch.S10E18.Big.Island.Heat.DVDRip.XviD.avi
Series contra Season e.g. and two digits are always better (Season 01, 02, 03 etc.), also for sorting.
And you use dots instead of dashes. Correct naming would be:
N:\Tv Shows\Baywatch\Season 10\Baywatch - S10E18 - Big Island Heat DVDRip XviD.avi
If you don’t like spaces, try underscores.
okay is
there a tool i can use to rename files quickly?
FileBot
ok ive found a free version i will try renaming the files and see if it will then work
I had a problem with the free version, I then did a search and found media center master can do the same thing which I already had installed so I used that to rename the files, then I did a new scan so far the files seem to be scanning but still no metadata?
logs attached
Plex Media Scanner.log (143.8 KB)
yes i have now tried several times and it still not working
Plex Media Server Logs_2018-08-04_11-18-05.zip (3.6 MB)
ok so I tried that and it didn’t really do anything, so I deleted the entire TV Shows library, optimised the library, then created a new library so far no metadata is downloading.
Metadata seems to now be downloading slowly thank you for your help
