Metadata refresh deletes all posters for certain movies
Server Version#: 1.41.5.9522
Player Version#: 4.145.1
Hi, I found that 10 movies from my library have the strange issue that a metadata refresh deletes all posters for the specific movie and leaves the poster with a thumbnail from this movie.
The posters for those 10 were working fine in the past, I don’t know when exactly this issue appeared. Funnily, they are all movies with Terence Hill and/or Bud Spencer, here is the list:
There are other Bud Spencer/Terence Hill movies in my library where this issue does not appear, for example:
Plex dance does not help. Anyone knows what could be wrong here? Maybe Plex API issue?
Thanks!
My guess would be a DMCA request. Search the forums; you’ll see plenty of other cases. Particularly since so many were affected and the same actors.
Indeed! I didn’t know this was an issue, thanks for pointing it out :slight_smile:
Thanks and kind regards!
You’re welcome. I would have suggested The Plex Dance, since already did…
In these cases its fairly common DMCA issue, I would recommend downloading and using local posters to avoid this.
